1998 Almera GTi value??
Hi all, I'm aware there are not many GTi's left and I have found one for sale locally. What is the value on one of these?
It's a 98 model with just over 100k on the clock?
So many factors and at this point probably whatever someone is willing to pay.
If there is minimal rust (let's face it there will be some) then maybe around 1k.
If it's very rusty then it's probably worth half that or less as someone will probably just break it.
It's a shame and they should probably start to be welded and saved.
Thanks Hally, I'm going to try and get hold of it. I'm not planning on breaking it so I guess I just need to check how much rust there is and where! Is there anything other than rust that can be a concern?
Not really, the engines are bulletproof and if you do have an issue a replacement is cheap enough.
The rear inner arches are the main area, pull the side carpets back in the boot and look around the seatbelt mounting bolt area. If there is rust there it has gone through multiple skins and will be a lot worse than it looks. Can be cut out and sorted but most people don't bother.
