Spec sheet moved to first page...
SPECIFICATIONS (As of August 09)
ENGINE
GA16DE (fully rebuilt August 09)
Stock Genuine Nissan Head Gasket and Head Bolts
76mm YCP Vitara Pistons (gives approx 8:1/8.5:1CR)
ARP Rod Bolts
Protech Turbo Manifold
Garrett GT22-52 Turbocharger
JWT S1 Turbo Cams
SR20DE GTi Throttle Body (60mm)
SR20DE MAF
Blitz Steel Mesh Cone Air Filter
Baileys BOV
2.5” Intercooler Pipe work and Front Mounted Intercooler
S14 200sx 370cc injectors
S15 200SX Fuel Pump
Nismo FPR
Remapped Nissan Micra K11 ECU (Fusion Motorsport)
3" Stainless Steel turbo elbow
2.5" Stainless Steel Exhaust
Fuchs Silkolene Pro 10w-50 Engine Oil
Prothane mount inserts and solid Alloy front engine mount
Cooling
Large FMIC
Large twin core Alloy Radiator (35mm thick)
12" Slimline rad fan
WHEELS & SUSPENSION
15” Wolfrace Sumo Alloys with 195/45/15 Nankang Ditch finder Tyres
BC Coilovers (8/6kg)
TRANSMISSION
1999 GA14DE gearbox
Slick50 gearbox treatment
Stage 3 XTD 6 Puck Clutch
GA16DE Fidanza Flywheel
BRAKES
Front:
GTi Disks and Calipers
Rear:
OEM Rear Drums and shoes
DOT 4 Fluid
INTERIOR
OMP Steering wheel and Boss Kit
Dash Mounted TIM Boost gauge
ProSport Wideband AFR Kit
Sparco Carbon Pedals
Partially stripped interior
COSMETICS
VZR Front Grille
Modified Ph1 Bumper to suit FMIC intercooler.
POWER and TORQUE
190whp/150wtq
PERFORMANCE
ENGINE
ARP Rod Bolts
JWT S1 Turbo Cams
SR20DE MAF
Baileys BOV
S15 200SX Fuel Pump
Nismo FPR
Cooling
Large FMIC
WHEELS & SUSPENSION
TRANSMISSION
1999 GA14DE gearbox
BRAKES
Front:
Rear:
DOT 4 Fluid
INTERIOR
COSMETICS
VZR Front Grille
POWER and TORQUE
190whp/150wtq
PERFORMANCE
