its for the split joint on my hotshots one. I've got some material but the one iv made is blowing already. I've emailed a couple of companies just wondering if anyone on here had used anywhere for this kind of thing
To be honest id use clear silicone sealant for joints on headers on a N/A motor.
MIJ uses clear silicone on all their work.
My turbo's downpipe joint that goes to the front pipe is using silicone sealant and even at those temps its absolutely fine. I use it on all my exhaust joints, i recently put my decat back in and used Silicone...
kia if you go with the gasket option and you find somewhere let me know as my hotshot could do with new gaskets, failing that, clear exhaust silicone is then my option
hmmm i havent had mine from new and in the past one of the secondaries has been "flattened" to get it to go around the sump, no way it will fit with a round pipe, custom made secondaries for me then
