Hi
I foolishly offered to change the timing chain on my impoverished daughter's 2003 N16 Almera 1.5S. With help from people on this forum I have removed the sump and timing cover. My original intention was not to renew the inlet VVT sprocket as it did not appear worn but then I found that Nissan's poor design means you have to remove the sprocket to get the chain off!`
In the Haynes manual it says you have to use a 3-bar air gun to allow the insertion of a 3mm allen key in a hole otherwise something internal could be sheared off, requiring the purchase of a new sprocket. It shows a picture where air should be applied and the use of the allen key, which is only to be removed after fitment.
Elsewhere I have read that this only applies to the Almera Tino, though I can't find the reference now.
Please see pics
Looking at my engine the place where air is to be applied has nothing behind it - you can see my towel under the hole.
Could someone please confirm that I can remove the sprocket without damaging it!
Please see pics
