In prep for the next turbo upgrade on the YD, I've run some numbers for the compressor. Any insight from anyone with some turbo understanding would be appreciated. Here's what I've got that seems suitable:
Stock:
36.34mm inducer
49mm exducer
Trim = 55
Proposed:
42mm inducer
56mm exducer
Trim = 56
Looking at the housing it won't take any bigger an inducer, but the trim (which I've read relates to flow) is kept to a similar value. Not so bad.
Also schooled up a bit more on A/R and I found this interesting on the Garrett website:
Attention then to the two #engine paragraphs.
If I wanted a higher trim I would need to get a larger housing anyway, but as for the top end performance from a higher A/R I wouldn't mind it being a made a little more biased towards it.
There's a 1.9 Vectra lad who is running much higher trims than I could with my current compressor housing, but on the same A/R @ 1.8 Bar and getting 228whp. So although we have the same A/R, my inducer will be a fair bit smaller, and I have my doubts I could reach similar figures with it (also I realise the engines are quite different, but it's a good starting point for comparison).
The same housing with this proposed compressor will give me a performance increase, sure, but will it be enough to get at least 200whp?
Stock:
36.34mm inducer
49mm exducer
Trim = 55
Proposed:
42mm inducer
56mm exducer
Trim = 56
Garrett said:When deciding between A/R options, be realistic with the intended vehicle use and use the A/R to bias the performance toward the desired powerband characteristic.
Here's a simplistic look at comparing turbine housing geometry with different applications. By comparing different turbine housing A/R, it is often possible to determine the intended use of the system.
Imagine two 3.5L engines both using GT30R turbochargers. The only difference between the two engines is a different turbine housing A/R; otherwise the two engines are identical:
1. Engine #1 has turbine housing with an A/R of 0.63
2. Engine #2 has a turbine housing with an A/R of 1.06.
What can we infer about the intended use and the turbocharger matching for each engine?
Engine#1: This engine is using a smaller A/R turbine housing (0.63) thus biased more towards low-end torque and optimal boost response. Many would describe this as being more "fun" to drive on the street, as normal daily driving habits tend to favor transient response. However, at higher engine speeds, this smaller A/R housing will result in high back pressure, which can result in a loss of top end power. This type of engine performance is desirable for street applications where the low speed boost response and transient conditions are more important than top end power.
Engine #2: This engine is using a larger A/R turbine housing (1.06) and is biased towards peak horsepower, while sacrificing transient response and torque at very low engine speeds. The larger A/R turbine housing will continue to minimize backpressure at high rpm, to the benefit of engine peak power. On the other hand, this will also raise the engine speed at which the turbo can provide boost, increasing time to boost. The performance of Engine #2 is more desirable for racing applications than Engine #1 since Engine #2 will be operating at high engine speeds most of the time.
