The SEX... lol
Actually I'm in the same situation, Top cable bushing is is just too small and Joe from 2JR seems to be very difficult person to contact. ICB fitted perfectly though. LCB fits fine too.
Can't comment on that as I've not contacted him yet hopefully get a quick resolution so I can fit the rest of the bushes.
grand update matey, how did you lads prime the turbo?
Well initially take fuel fuses out pump & injectors, crank engine so oil is coming through the inlet pipe TT recommend 300ml to ensure inlet isn't blocked. then bolt up inlet repeat cranking until oil is flowing out of the turbo outlet then reconnect hard pipe & then put everything else back together.
http://www.turbotechnics.com/www/?page_id=609
Ok this weekend was a hectic one so only had time to carry out two little bits on the car one namely to replace the brake lights to LED Cree units that are super bright and have 10 LEDs in total and to fit a replacement set of rear speakers as the OEM paper cones were far from at their peak. I bought some 6x4 speakers from eBay and pulled the old set out only to find that only two of the fixing would secure the speaker. So it was decided to cut the old speakers apart and use the outer piece as a fixing plate.
Angle grinder at the ready, I didn't cut it against the pad this was only for picture sake.
Love it when a plan comes together
The rest was well rushed as I had to go out so will update with pictures later in the week, after removing the old cone and cleaning the surface of the fixing plate double-sided tape was used to cushion the new speaker to the plate and then the holes were drilled out as the edges of the new speakers were obstructing the original fixing holes.
Once all metal shavings were cleaned off the speaker the units were bolted back together and into the OEM parcel shelf. Only sweet clear sounds now ;)
  • Like
Reactions: edk
