hey guys....
was driving back from the girlfriends house tonight, when all of a sudden, the airbag light just started flashing, dont know why the hell it would, havent hit anything..
i found this on the sr20forum for resetting it..
1. Open driver's door
2. Turn ignition switch from "OFF to "ON"
3. Press driver's door switch at least 5 times within 7 seconds after turning ignition switch "ON".
SRS is now in Diagnosis mode.
4. "AIR BAG" warning lamp operates in diagnosis mode as follows:
1. on (7 sec) off (2 sec) on (3 sec) off (2 sec) on (3 sec)....
Intermittent problem has been detected in the past.
2. on (7 sec) off (2 sec) on (3 sec) off (2 sec) on/off (.5 sec)
system has problem and needs to be repaired.
i followed the procedure, then the light kept flashing in 3 second intervals.. (as opposed to 1 second when it originally came on) tried it again and the light went off.. then after taking it for a test drive, the light came back on after around 10 mins...
havent done anything to the car.. took off the back wheel tonight to have a look at the brake pad as it was making a lot of noise, took off one bolt, but couldnt get the other off.. put the bolt back on and left it.. other than that, its had a full service on Friday...
any one any ideas?!
thanks
any one any ideas?!
thanks
