Regular Price: $189.99
SPECIAL PRICE: $124.99
Quick Overview
The long awaited and obsessively tested "drop in" bump steer kit for the B13, B14 and B15 (all models) is finally available for pre-purchase on a Group Buy. Made from forged steel and billet aluminum, our bump steer kit drops right in the Sentra spindle with no modification. This means no drilling, cutting, etc and the ability to change back to stock. The heim joints are sealed from dust and debris for long life and include forged spacers for Sentras that are stock height, to low and extra low. Our kit will make your car easier to drive by providing less kick back through the steering wheel when bumps are encountered. In addition, the kit will significantly reduce tire wear by reducing the amount of toe change and therefore scrub that the front tires are subjected to. You WILL need a front toe alignment after the install.
Ships 12/31
Included in the kit are:
(2) Forged Tapered Bolts
(4) Forged Spacers / Height Adjustment
(2) Sealed Heim Joints
(2) Billet Aluminum Tie Rod Ends
(1) Associated hardware, install instructions
