E
ellingtj
Just done this on my N16 and it worked.
N16 Service light reset Etc
SELF DIAGNOSIS and CONFIRMATION/ADJUSTMENT MODE
1. START ENGINE.
2. TURN AUDIO SYSTEM OFF.
3. WHILE PRESSING THE INFO SWITCH (on the dash, not the steering wheel remote),TURN THE VOL CONTROL 30 CLICKS OR MORE (dosen't matter which way).
When self diag and conf/adj mode is started the screen will display SELF DIAGNOSTIC and CONFIRM/ADJUSTMENT.
Select CONFIRM/ADJUSTMENT.
Select SERVICE.
You should be able to reset and make any adjustments on the screen displayed.
If you need to go back a screen at any stage, use the "BACK" button.
1. START ENGINE.
Select SERVICE.
