Eddies Ride
Difference is that mine IS identical. But u went from GA to Gti. Mines the same engine and using same mods etc.
-mobile phone post-
So what engine mods are you currently sporting then Eddie? It's a decent figure with few mods. A good base figure to work from. Well done chap.
dang both whp and tq are nearly the same numbers......
I have never expected the sr20 can pull such high torque, I thought only QR does ....
Good Job Eddie, keep up the good work.
You're right mate. It's handy that Eddie has fitted the exhaust before doing many other mods. It's usually only after people have hit a wall with other mods you'd fit that size of exhaust. Eddie = Usefull.
i dont think 161bhp is that impressive tbf, sound just about normal. the first time i went to HLM with my cams, my best pull was with 15* ignition timing. a run down after the power run to show bhp IS better than whp. whp has many variables, bhp is the power from the engine.
dboi
true ^
at the level of mods, the difference between say 15* and 19* ignition timing will make the most difference *all things being equal. hence my 155bhp with standard exhaust mainfold and standard GTi exhaust system 1.9'. iirc the most any ukdm DE with standand exhaust mainfold (oe cams) has made - timing.
