thanks
, yeah the wheels, interior, leccy mirrors and gear selectors will live on in the UK's first ve'd n16 :shades:
ok so i got the 50a series gear selector assembly off of garry's old di sport+ and everything connected up perfectly, unfortunately when the gearbox is in neutral the gearstick sits like it's in third, which was no use obviously, but luckily the fix was very simple
firstly here is a pic showing the difference between the 30a selectors (top) and the 50a selectors, as you can see the end of the 50a selectors is straight compared to the 30a ones which are turned to one side, also the stabiliser rod to rear mounting bracket connector is slightly different (not shown in pic)
so with the gearstick position problem in mind i worked out i just needed to extend the available adjustment at the gearstick end mounting points, so this is what i did, then i also had to cut a little of the front lugs of the mounting plate to allow it to slide forward about 8mm and make use of the extended slots i had made, once i put it back on it placed the gearstick back in the stock position, so i fitted up my energy suspension poly bushes and fitted it up properly :shades:
(stock rear mount on the right, modified one on the left)
this is a very easy modification and much simpler than cutting and welding imo
now all that remains is the powersteering pump to be modified/hooked up and then it's just the wiring
wish me luck :lol:
