n15 1.4 1999 abs light on
hi all
i have an n15 1999 1.4 with an abs light on , MOT due
wondering can i try to disable/reset it?
Also the parking brake light is on for the handbrake regardless of handbrake
being up or down, easy fix?
There is a airbag reset guide in the technical section, top up your brake fluid the handbrake light comes on sometimes when the level is low.
Do you have an OBD-II reader? Worth reading off the codes first, in case there is something more serious up. Handbrake could be a microswitch which might respond to some WD40.
