Steven has his dyno tested at the same place so comparitive figures.
I know, that's why I think mine needs tweaking. Not much more HP thaqn your though my HP graph is pretty much a straight diagonal line. Got a scan of yours?
sounds just like mine how does it run while driving then? smae as mine? lumpy and like it just not right?
Mines's like that with the JWTs. Just have to feather the clutch a lot under 2.5k. Light flywheel does not help ; slightest increase or decrease in throttle or clutch is magnified. The revs drop quick and when the engine catches you're sure it will stall. Takes a bit of faith and work to get it sussed. But when you floor it at 4k in 2nd, change up at 6.5k through to 5th it's worth the pain in traffic jams.
Definately think a remap is required to get the full benefit, though. Esp with other mods.
What do you guys think about timing, was reading that too much advance with these sort of cams overcooks things and that the cams are designed to work best with stabdard timing?
theres no fault with the cams... you just have to learn to drive the car.
