*Update*
Current Spec
VZR N1
Engine
JWT 9lb Flywheel
GSpec Stage 3 Clutch
New OEM Thermostat
New OEM Rotor Arm/Distributor Cap
OEM N1 Chain Tensioner
2 Piece Engine Mounted Drive Shaft
Custom 4-1 Manifold
Custom Solid Fabrications 2.5" Catback
Aluminium 3" Core Radiator
Catch Can Breather Setup
DaleSpec 3.5" Intake Pipe
Blitz Sonic Power Filter
Hot Wire HT Leads
A/C Removed
Odessey Battery Wing Mounted
Fuseboxes Relocated
Chassis
FRP Bonnet
Custom Subframe Locating Collars
OEM Track Rod Ends
Steering Rack (Poly Bushed)
OEM Drop Links (Poly Bushed)
Powder Coated Front ARB (Poly Bushed)
OEM Wishbones (Poly Bushed)
4x Poly Engine Mounts
Meister-R Zeta Coilovers 7/5
Powder Coated Cusco Top Strut Brace
Custom Rear Strut Top Brace
Custom Lower 2 Point Subframe Brace
Rear Trailing Arm (Poly Bushed)
Powder Coated Whiteline Rear Anti Roll Bar with Custom End Links
Rear Dog Bone Beam Mount Thing
H&R 15mm Spacers and Extended Studs
Interior
Personal Neo Grinta 330mm Wheel
HKB Boss Kit
NRG Rev.3 Snap Off Boss Kit
Flocked Dash
Custom Extended Gear Shifter
Recaro Seats on Custom Rails
Omori Gauges
Sound Deadening Removed
Apexi RSM Black
Broadway 280mm Rear View Mirror
Wheels/Brakes
Wilwood Midilite Front Callipers
Ferodo DS2500 Pads
Yellowstuff Rear Pads
Custom HEL Braided Lines
Non ABS Converted
15x7" Team Dynamics Pro Race 1.2 & Federal RSR
16x7" Modex KS-05R & Yokohama Parada Spec 2's
15x6.5" Enkei Tarmac ES & Hankook RS2's
*Past*
So yeah, its getting to the point where its on the road now, only got the registration process to wait for.
It flew through its MOT yesterday only things to note were the brake discs are a bit scabby and the drop link bushes are perished. I have item to replace these in the garage anyway.
Its hands down the cleanest N15 shell I have seen, all the bolts still have the factory zinc plating on them, all the plastics are intact as are the clips, the downpipe is a little scabby on the heatshields but the exhaust is still gold and shiney.
Its been very well looked after, has new oil, new oil filter, new pollen filters, new belts, new coolant and a new rad cap which are all Pitwork items
So...
Its completely stock, had some Ultra Wire HT leads on it but they are now on the Autech, and an aftermarket panel filter which fell apart when I removed it, its on some unknown lowering springs too, but the ride is very compliant.
Its a lightweight model with windy windows, no central locking, no sunroof etc
its fucking filthy everywhere so I will be getting my teeth into it and getting it to where I want it
it begins..... again
Current Spec
VZR N1
Engine
JWT 9lb Flywheel
New OEM Thermostat
Custom 4-1 Manifold
Hot Wire HT Leads
A/C Removed
Fuseboxes Relocated
Chassis
FRP Bonnet
OEM Track Rod Ends
Interior
HKB Boss Kit
Flocked Dash
Omori Gauges
Apexi RSM Black
Wheels/Brakes
Ferodo DS2500 Pads
Non ABS Converted
*Past*
So...
.........Good man....
