am i right??between subframe bolts or the arb mount, either is fine.
can you help me also where to put the jack and the axle stands at the back?see above for fitted picture![]()
i ment at the back of the car... where do you put the jack and the axle stands?if you mean the box section of the chassis, then no pal. your pictures above are fine and are where i use
Jack in middle of beam. Stand either side of jack on beam.
unless you are working on suspension
True, then the stand goes on the noticeable jacking point on the sill but you should still jack up on the beam to avoid damaging the sill.
I should do a how to![]()
Time to run a 14 david!
